πΌοΈ
I transformed a sloping, uneven backyard into a level and functional outdoor space. The project involved constructing a concrete retaining wall, raising and supporting the existing fence, then backfilling, compacting and carefully grading the yard to create a level surface. Once prepared, I laid new Sapphire Buffalo turf to establish a lush, durable lawn. To complete the transformation, I restored the existing Colorbond fence by spray painting it in Dulux Monument, giving the backyard a clean, modern finish and dramatically improving the overall appearance and usability of the space.
Concrete β retaining wall footing/base and wall construction
Reinforcing steel (reo bar) β reinforcement within the concrete retaining wall
Steel fence posts/extensions β to raise and support the existing Colorbond fence
Formwork timber/plywood β forming the concrete retaining wall
Timber stakes and bracing β supporting formwork during construction
Structural/fill soil β backfilling and raising the backyard level
Compacted road base/crushed aggregate β where required for stable foundations and levelling
Turf underlay/topsoil
Treated pine sleepers β retaining/edging along sections of the boundary
Drainage gravel and agricultural pipe β where required behind retaining structures
Dulux Monument exterior paint β refinishing the existing Colorbond fence
Metal primer β preparing exposed or repaired fence surfaces before painting
Fasteners and fixings β screws, bolts, brackets, anchors and fence hardware
Mini loader
Plate compactor
Concrete mixer
Wheelbarrow
Shovels
Landscaping rake
Lawn levelling lute
Lawn roller
Spirit level and string line
Tape measure
Circular saw
Drill and impact driver
Angle grinder
Hammer and mallet
Screed / straightedge
Concrete trowels and float
Pressure washer
Paint spray gun / airless sprayer β applying the Dulux Monument finish
Clear and excavate the backyard
- Step 2:
Establish finished levels
- Step 3:
Construct the retaining wall
- Step 4:
Raise and reinforce the existing fence
- Step 5:
Backfill the yard
- Step 6:
Compact the fill
- Step 7:
Final grading and levelling
- Step 8:
Prepare and lay the lawn
- Step 9:
Prepare the existing fence
- Step 10:
Spray-paint and finish
