My partner and I built 'Eddie', our teardrop caravan, together every weekend over 6 months so we would be able to spend more time together and in nature. Every weekend was a new challenge; neither us had construction experience so we spent our evenings watching Youtube videos learning how to safely run electrics and waterproof effectively and the weekends covered in paint and sawdust. Our many mistakes have become our favourite parts of the project and we've taken it for many trips to Gippsland and beyond with friends and family. We love Eddie!
https://www.bunnings.com.au/goliath-700mm-650n-black-gas-strut_p4230059
https://www.bunnings.com.au/structaply-2400-x-1200-x-17mm-f14-plywood-formwork_p0390072
https://www.bunnings.com.au/zenith-10g-x-50mm-gold-passivated-type-17-countersunk-head-timber-screws-50-pack_p2409143
https://www.bunnings.com.au/2440-x-1220mm-3mm-plywood-pine-premium-bc-grade_p0340267
https://www.bunnings.com.au/crommelin-100mm-membrane-applicator-brush_p0960316
https://www.bunnings.com.au/crommelin-1l-exterior-grade-brushable-waterproofer-1l_p0961573
https://www.bunnings.com.au/selleys-310g-translucent-roof-and-gutter-silicone-sealant_p1234919
https://www.bunnings.com.au/foilboard-green-10-2400-x-1200-x-10mm-2-88m2-insulation-panel_p0125954
https://www.bunnings.com.au/ark-coupling-lock_p6100331
https://www.bunnings.com.au/craftright-standard-trailer-ball-mount-kit_p1006341
https://www.bunnings.com.au/kt-solar-12v-120w-monocrystalline-solar-panel_p0510973
https://www.bunnings.com.au/narva-50a-6mm-red-black-black-sheath-twin-sheath-cable-5m_p0047797
https://www.bunnings.com.au/deta-15a-caravan-inlet_p0087089
https://www.bunnings.com.au/deta-16mm-black-cable-gland-16mm_p0380992?store=6400&gclsrc=aw.ds&gad_source=1&gad_campaignid=23536369919&gbraid=0AAAAADtbEB9fVIGIEBZjshrDwf5K4CKfv&gclid=Cj0KCQjw4JbTBhCoARIsALWUaBtJzZiw-IS56HN9t0Qv7IjxlLn0cqeu_UMUdBAGv5dFiQrzSGSDUVYaAubCEALw_wcB
https://www.bunnings.com.au/deta-10m-x-20mm-medium-duty-corrugated-conduit_p0829437
https://www.bunnings.com.au/narva-12v-model-37-led-plug-and-play-submersible-trailer-lamp-kit-suitable-for-boat-trailers-up-to-7m-22-_p1015889
https://www.bunnings.com.au/zenith-8g-x-15mm-galvanised-button-head-stitching-timber-screws-35-pack_p2410091
https://www.bunnings.com.au/70-x-35mm-framing-mgp10-untreated-pine-2-4m_p8030010
https://www.bunnings.com.au/click-multicolour-heatshrink-cable-management-kit-80-pieces_p0381120
https://www.bunnings.com.au/pinnacle-m10-x-100mm-stainless-steel-hex-bolt-and-nut-2-pack_p2300000
https://www.bunnings.com.au/dulux-4l-white-ceiling-paint_p1370215
https://www.bunnings.com.au/ultimate-20l-red-plastic-fuel-can_p0106572
https://www.bunnings.com.au/adventure-products-20l-diesel-fuel-can-and-pourer_p3400262
https://www.bunnings.com.au/timbermate-1kg-agnew-s-water-putty_p1560643
https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-multipurpose-gap-filler_p1230010
https://www.bunnings.com.au/ozito-pxc-18v-cordless-staple-gun-pxsgs-5021-skin-only_p0136009
https://www.bunnings.com.au/scotchblue-24mm-x-54-8m-original-multi-surface-painter-s-masking-tape_p1669657
https://www.bunnings.com.au/syneco-130-145mm-polished-adjustable-toggle-latch_p4150156
https://www.bunnings.com.au/grunt-50mm-x-10m-flashing-tape_p0811404
https://www.bunnings.com.au/goliath-70-x-32mm-clear-reflector_p4230088
https://www.bunnings.com.au/9kg-gas-bottle-holder-adjustable-lockable-for-caravan-camper-trailer-jayco_p0969645
https://www.bunnings.com.au/gasmate-safe-lok-lcc27-4kg-propane-gas-cylinder_p0242774
https://www.bunnings.com.au/boyle-250ml-craft-pva-glue_p0400203
https://www.bunnings.com.au/trojan-3-piece-plier-set_p0126943
https://www.bunnings.com.au/crommelin-75mm-membrane-applicator-brush_p0960504
https://www.bunnings.com.au/uni-pro-professional-no-drip-heavy-duty-caulking-gun_p1670252
https://www.bunnings.com.au/ozito-pxc-18v-cordless-1-2-brushless-impact-wrench-pxbws-230-skin-only_p0467360
https://www.bunnings.com.au/craftright-20oz-solid-claw-hammer_p0095320
https://www.bunnings.com.au/kango-38mm-soft-face-mallet_p0579780
https://www.bunnings.com.au/ozito-pxc-18v-jigsaw-pxjss-600-skin-only_p6290477
https://www.bunnings.com.au/firemate-refillable-fire-ignition-gas-lighter-2-pack_p0260183
https://www.bunnings.com.au/craftright-4-piece-adjustable-wrench-set_p0918219
https://www.bunnings.com.au/stanley-compact-fixed-blade-folding-knife_p0519510
https://www.bunnings.com.au/full-boar-40-piece-impact-torsion-bit-set_p0170513
https://www.bunnings.com.au/ryobi-4-piece-countersink-drill-bit-set_p0525187
https://www.bunnings.com.au/paint-partner-100mm-fence-brush_p0794482
https://www.bunnings.com.au/craftright-300mm-quick-action-clamp-set-2-piece_p0919678
https://www.bunnings.com.au/crescent-lufkin-150mm-6-2-in-1-extendable-speed-square_p0671734
Design Shape and frame with 3D Software, determining the materials needed and assembly process.
Cut down old trailer and reweld into shape for teardrop base, new axle and wheels.
Build and assemble plywood & pine frame onto trailer base, bolt & screw down.
Run electrics through the frame & fill plywood cutouts with insulating foam board.
Clad frame with 3mm ply over entire frame and waterproof membrane applied to entire frame and underside.
Cut and clad frame with aluminium sheeting, J mold over all edges to waterproof and hold in place.
Waterproof hinge and backdoor installed.
Build an install internal finishings (Headboard and cupboards for the cabin & Cupboards and bench for the kitchen).
Windows and doors installed, electrics installed in interior.
Attach locks and Electrical box at front, Jerry can holders & Gas bottle holders
This is so cool!! Why did you call it Eddie?… and can I order one?
Eddie is short for Edamame, because it looks like a green bean! Never thought about making more to sell, definitely on the cards in the future 😁
Hello @Ben_Dewhurst
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your D.I.Y teardrop caravan project.
What an amazing build! Eddie is absolutely charming, and it's even more special knowing you built it together from the ground up. The craftsmanship and care really shine through, and you've created something that's perfect for making wonderful memories in the great outdoors.
Thank you for sharing the progress photos, they made the journey just as enjoyable as the finished result. Wishing you both many more adventures with Eddie!
Hello @HarrietSpittle
It's great to know that @Ben_Dewhurst's project has inspired you. Should you ever decide to get one for yourself, please don't forget to post a photo of the caravan.
Were keen to hear more about all your projects and plans around the house and garden. Please feel free to reach out if you need assistance or would like to share a project with the community.
Thanks Eric! Very inspired indeed, I’ve always wanted to get one but I didn’t realise you could make it yourself - might have to do some shopping this weekend for some tools if I can’t put in an order with Ben! Although I doubt mine would end up quite as nice 😂😅
Ps: Edamame is a great name! Two peas in a pod! 🫛
This is a great project @Ben_Dewhurst! I think it's a fantastic caravan! What is your favourite feature you put in
Wow, this is incredible and looks like you had a lot of fun building it! Love the breakdown of the steps - very helpful!
I also think you should definitely make more to sell, I’d be very interested!
Hello @mitchellhan
It's great that @Ben_Dewhurst project has inspired you. Should you decide to make one or purchase a tear drop caravan, make sure to post a picture!
Hello @anglap
Let me tag @Ben_Dewhurst to make them aware of your kind words and interest in purchasing the tear drop caravan.
Hi @mitchellhan , definitely the projector! Watching movies on a cold night while camping is awesome 👍
Hi @anglap , I'm thinking about it more and more considering the interest I'm getting. I'll definitely keep you posted , just gotta get my ducks in a row 😊
