From forgotten to feature piece! I transformed these dated bedside tables into playful designer-inspired furniture using paint and for the handles I used wooden drink coasters sourced from Kmart! I completed this project to challenge myself creatively while giving quality furniture a second life instead of adding to landfill. It shows that with a few Bunnings supplies and a vision, anyone can create something unique, stylish and sustainable.
Scotch Blue Tape
https://www.bunnings.com.au/scotchblue-24mm-x-54-8m-original-multi-surface-painter-s-masking-tape_p1669657
Ryobi orbital sander
https://www.bunnings.com.au/ryobi-18v-one-hp-brushless-125mm-random-orbital-sander-rros18c-tool-only_p0539761
Porters Paint Old stone Wall
https://www.bunnings.com.au/porter-s-2l-old-stone-wall-eggshell-finish-broadwall-washable-paint_p0163043
British Paint - Daintree Beauty for the green strips
Kmart wooden drink coasters
Sealed with Cabot’s clear
https://www.bunnings.com.au/cabot-s-500ml-satin-water-based-cabothane-clear-polyurethane_p1522368
ryobi orbital sander
Scotch blue tape
- I found a pair of solid timber bedside tables that had good bones but were looking a little tired. After giving them a thorough inspection, I decided they would be perfect for a makeover.
2. I removed the handles and lightly sanded all surfaces to remove the old finish and create a smooth base for painting. I then cleaned away all dust with a damp cloth.
3. I applied a primer followed by 2 coats of Porters paint - Old stone Wall, allowing each coat to dry completely before lightly sanding between coats for a smooth finish.
4. Once the paint had cured, I carefully measured and masked the drawer fronts with painter’s tape to create evenly spaced stripes. I painted the exposed sections in green and removed the tape while the paint was still slightly wet to achieve crisp, clean lines.
5. After the paint had fully dried, I applied a clear protective topcoat to help protect the bedside tables from everyday wear and make them easy to clean.
6. I wanted large wooden handles so I sourced wooden drink coasters from Kmart and mounted a. Bracket on the back and attached to the bedside drawers. The fresh green striped design gives them a modern, unique look while keeping the original furniture out of landfill.
