We transformed our dark, dirty garage into a stylish gym and wellness retreat. By relocating the attic stairs from the centre to the side, we opened up the back space and cleverly utilised the area underneath for a chest freezer and tumble dryer. The renovation focused on fresh paint and new Gyprock walls, complemented by new gym equipment, a sauna, and revamped existing pieces. The result is a modern, calming sanctuary that's now a pleasure to use everyday.
- Timber
- Paint
- Gyprock
- Gyprock Topping Compound
- Cornice Cement
- Tough as Nails
- Timber Screws
- Masonry Screws
- Easy Screed Mix
- Paint Brushes
- Paint Rollers and Trays
- Drop Sheets
- Silicone
- Painters Tape
- Skirting Boards
- Concrete
- Exhaust Fan
- Downlights
- Safety Goggles and Masks
- Disposable Gloves
- Corner Beading for Gyprock walls
- Handrail Wall Brackets
- Ozito Cordless Drill and Sander https://www.bunnings.com.au/ozito-pxc-18v-3-piece-kit-p3k-400_p0738798
- Staple Gun https://www.bunnings.com.au/arrow-t50-heavy-duty-staple-gun-all-purpose_p5911696
- Tin Snips https://www.bunnings.com.au/sterling-180mm-safety-rounded-tip-black-panther-industrial-snips_p0754220
- Caulking Gun https://www.bunnings.com.au/dripless-300ml-heavy-duty-caulking-gun_p1662783
- Laser Level https://www.bunnings.com.au/ozito-10m-range-cross-line-laser_p0423728
- Collated Screwdriver https://www.bunnings.com.au/dewalt-collated-screw-magazine-to-suit-collated-drywall-screwdriver-dcf620-dcf6202-xj_p0612137
- Step Ladder https://www.bunnings.com.au/syneco-100kg-3-step-domestic-slim-line-aluminium-ladder_p0363423
- Plaster Trowel https://www.bunnings.com.au/kango-280mm-plaster-trowel_p0403134
- Hammer
- Crow Bar
- Chisel
- Demolition of old attic stairs. Used a carpenter for this initial stage of removing the old stairs in the middle of the garage and building new stairs to the side of the garage.
- Electrician did wiring for new light switches, GPO's and installed gym track lights.
- New glass door fitted to rear of garage.
- Installed the Gyprock plasterboard to new staircase timber frame using the collated screwdriver.
- Installed Gyprock plasterboard to the exposed brick walls using cornice cement.
- Installed timber wall panels to exposed brick walls using cornice cement and masonry screws.
- Custom mirror installed to main gym wall with screws.
- Painted exposed timber beams in Dulux Domino (black paint)
- Painted timber wall panels in Dulux Domino paint.
- Jointing tape was used for the plasterboard joins then filled with Gyprock All Purpose compound.
- Sanded all the Gyprock joins with Builders Edge Sanding tool until surface was smooth.
- Skirting Boards attached with Tough As Nails or Screws
- Painted the walls in Dulux Beige Intent
- Painted the stairs & handrail in Taubmans Cotton Ball
- Painted the new glass door in Taubmans Cotton Ball
- Painted the skirting boards in Taubmans Cotton Ball
- Painted the entire garage concrete floor with White Knight Ultra Pave in Champignon
