The deck renovation began after my daughter slipped on the old, weathered
deck, which had become dangerously slippery. Determined to make it safe again,
I took on the challenge. The deck was pressure washed, and every board sanded
on my hands and knees, with fresh decking oil applied, and all the railings and
support beams repainted. There were a few DIY mishaps, including one sanding
tool swallowing the other's power cord, a trick for new beginners! The finished
deck now looks amazing and is a safe, welcoming space and a reminder that
stepping outside your comfort zone can be incredibly rewarding.
Cabots Deck Clean
https://www.bunnings.com.au/cabot-s-1l-deck-clean-1l_p1521451
Sanding pads (and lots of them) - for the belt sander, palm sander and hand sanding
https://www.bunnings.com.au/ryobi-100-x-140mm-10-piece-detail-sanding-set_p0417391
https://www.bunnings.com.au/ozito-detail-sander-assorted-grits-sanding-sheets-10-pack_p6291702
Decking oil (10L)
https://www.bunnings.com.au/feast-watson-4l-merbau-matt-look-decking-oil_p1520580
Wood Hardener
https://www.bunnings.com.au/earl-s-250ml-wood-hardener_p1585306
Wood filler
All weather paint
https://www.bunnings.com.au/taubmans-4l-accent-semi-gloss-all-weather-exterior-paint_p0079556
Hose
Oats Bucket
Gerni High Pressure Washer
https://www.bunnings.com.au/gerni-5000-1885psi-1800w-high-pressure-washer_p0235517
Belt Sander
https://www.bunnings.com.au/xu1-810w-corded-belt-sander_p0253633
Wire broom
Cabots Applicator
https://www.bunnings.com.au/cabot-s-decking-oil-applicator_p1660060
https://www.bunnings.com.au/rocket-sanding-block-holder-with-medium-grade-sponge_p1661396
AEG Multi Tool - borrowed from a friend
Ryobi Sheet Sander
https://www.bunnings.com.au/ryobi-280w-1-3-sheet-sander_p6210546
Ryobi 18V One+ Palm Sander
https://www.bunnings.com.au/ryobi-18v-one-palm-sander-rps18-tool-only_p0371771
Deck Oil applicator
https://www.bunnings.com.au/monarch-230mm-woodcare-deck-pad-applicator_p0328106
Paint brushes
https://www.bunnings.com.au/monarch-3-piece-all-purpose-project-brush-pack_p0319018
Sweep desk with broom.
Clean deck using hose and high pressure wash using Gerni, wire broom and Cabots deck clean.
Before
AFTER - stairs
AFTER - Deck
- Step 2:
And next come the hours and hours of sanding…..
And the death of AEG multi tool
- Step 3:
Using the applicator, of which I tried the Cabots and a number of others and settled on the Monach one which seemed easier on my back. A glass of champagne may have beens at at the end of the deck for motivation 😊
- Step 4:
Apply a second and third coat of decking oil to finish.
Before and after
And to let it dry…..and wait for the rain to see it bead!
- Step 5:
Finish the rail painting….when you think you can leave the sides and discover you cant, you just keep going.
- Step 6:
Finished - Sit back and admire the hard work.
THE END
