Being off work with an injury I needed something to do with all the extra time. I built this native bee hive and enclosure as I needed to protect the hive from the harsh summer sun !
42x19 pre oiled merbau
42x42 pre oiled merbau
90x35 untreated pine
99x35 Victorian Ash
100x100mm treated pine post
19mm plywood
50mm gal timber acres
75mm gal timber screws
30mm stainless decking screws
Treasure chest hinges
Ball bearing latch
Small cabinet hinges
Selleys outdoor no more gaps
Selleys timber floors no more gaps
Bondal outdoor bitumen paint
Makita mitre saw
Makita impact drill
Makita screw drill
Makita jigsaw
Makita orbital sander
Makita circular saw
Ozito planer
Amazon router
PH2 Phillips bit
Drill bits ranging from 3mm - 13mm
13mm forstener bit
Sikkens varnish
Driver for decking screws comes with screws
Ultra grain clear
Round-over router bit
Paint brushes
Turpentine
I found plans for a OATH standard dimension beehive and followed that. The hive itself is made from Victorian Ashwood. It has a Perspex separator and splitting bars. Plenty of instructional videos and plans to follow for the hives. Super simple. Just remember unless your splitting/educating from another established hive you won't need to build your own box . Most bees come with hives .
After cutting the timber for the bee hive I moved onto the enclosure .
- Step 2:
I drew a rough plan of how much space I wanted around the hive and worked off that .
I started with the base which was using the 90x35mm untreated pine . I used untreated as that's what I had around but I'd probably recommend using the outdoor treated version.
Cut all the needed timber ( 90x35 and 19mm ply ) the only is for the floor inside the frame . Pre drill with the correct size drill bit before every screw . I chose to also use a countersink bit . Proceed to screw it all together with the 50mm gal screws except for the floor plywood
- Step 3:
Cut your 42x42mm merbau at whatever length you'd like to suit your hive. Screw them on the inside of the frame you made and then measure and cut your plywood to suit . This goes between your posts
