I was making over a room in our house as a surprise games room/ whiskey den for my husband, and a big part of that was a new bar fridge. I really wanted it to match the room, rather than be a big white rectangle in a dark room, so decided to give it a makeover.
https://www.bunnings.com.au/porta-15-x-11mm-2-4m-clear-pine-insert-mould_p0258492
https://www.bunnings.com.au/porta-22-x-22mm-2-4m-clear-pine-edging-round-external-corner_p0092716
https://www.bunnings.com.au/timbermate-250g-walnut-wood-filler_p1560708
https://www.bunnings.com.au/cabot-s-250ml-walnut-gloss-water-based-stain-and-varnish-250ml_p1520328
https://www.bunnings.com.au/loctite-30ml-vinyl-fabric-and-plastic-flexible-adhesive_p0685050
https://www.bunnings.com.au/selleys-400g-kwik-grip-gel-vertical-contact-adhesive-400g_p1233418
https://www.bunnings.com.au/pro-renovator-150mm-plastic-scraper_p1610000
I went and found a perfect sized bar fridge to fit where I needed it
- Step 2:
I sourced some vinyl online in almost the exact same shade as the new Dulux Raku wall colour.
- Step 3:
I started by covering the sides of the fridge in the vinyl wrap, making sure to get the air bubbles out with a plastic scraper as I went.
- Step 4:
Next I had the difficult task of starting to tackle the grill at the front. I used loctite vinyl glue on the corners of the big pieces, and edges of the smaller pieces, for durability.
- Step 5:
I measured the door frame and headed to bunnings for some timber moulding.
- Step 6:
I ended up buying 3 lengths of moulding. One to cover the corner edges, one to cover what was left of the sides, and one to cover what was left on the front.
- Step 7:
I measured 2 more times, and then cut my edge trim to start my frame, and attached it with Selleys kwik grip. I don't really have any pictures of this stage except this terrible one
- Step 8:
I then did the same with the front and sides, so the door showed minimal white, making sure to have cut outs for the handle and lock barrel
- Step 9:
I filled any small gaps with Timbermate walnut wood filler, and stained it with Cabot's water based walnut stain and varnish
- Step 10:
And the end result showing the front and sides. Time to put it in place and stock it!
