Hi all,
I installed two sets of LYTWORX Double Filament LED Festoon Lights a few weeks ago (connected the 25 pack to the 10 pack). They worked fine initially, but I’ve noticed a when I turn them on now, they start dim and take around 5-10 minutes to build up to full brightness. This didn't happen when I first installed it, it turned onto max brightness fine. I’ve double-checked the remote isn’t stuck on a lower brightness setting (mine has 4 brightness levels) but even when it’s set to max, it starts dim and climbs slowly. Is this normal, or a sign something’s wrong?
Things I've tried
- Firmly reseated the connector between the power board and the light strand
- Confirmed brightness setting on the remote is at max, not on a dimmer setting
- No visible damage, cracks, or moisture in the connectors or bulb sockets that I can see (the lights are not under cover but the power board/connector are)
- Tried multiple power sockets - both work, but the lights start dim for both
Trying to figure out if this is just how they behave (even though it didnt used to) or if it points to a fault before I take it back to Bunnings.
Pictures attached for reference - first pic is how it will start dim for 5-10mins, second pic is full brightness
Thanks in advance!
