We gave our spare concrete slab a bit of a transformation into a small fire pit area for myself and my partner. We did this over a weekend and love how it turned out!
https://www.bunnings.com.au/ki-carma-20kg-10-20mm-drainage-gravel_p3460052?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=23022021534&gbraid=0AAAAADtbEB8FvO35sdZipMXupxQnyrrSK&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU5I5YWGFPDTRY3Jwe5fUoWelcM2fAwzcB_R_OqHHiKf2-tgtMiTuAAaAvXGEALw_wcB
https://www.bunnings.com.au/ki-carma-20kg-decomposed-granite-landscape-stones_p0261624?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=23022021534&gbraid=0AAAAADtbEB8FvO35sdZipMXupxQnyrrSK&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU5fqMWLsfA_FFxx3dSHqgZFqgoF0wBHNB1WFUfoMhN2dChXux-eXNkaAoz-EALw_wcB
https://www.bunnings.com.au/davco-20kg-smp-evo-tile-adhesive_p6650266?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB_su42C93vD3yoUF_0T50d8h&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU4_khGTjzijxcJNmIufnN6jWhPNWi-5KBowv2Ea4tE6wgOBkQa-CD8aAvBmEALw_wcB
https://www.bunnings.com.au/brighton-masonry-200-x-100-x-50mm-charcoal-mypave-215-paver_p3451529?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=23022021534&gbraid=0AAAAADtbEB8FvO35sdZipMXupxQnyrrSK&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU4dfXgjiEvxoEyTGC8qPDz7golJSwdr5W4icBrTahQzThOtmn40YNMaAr9XEALw_wcB
https://www.bunnings.com.au/glow-rust-heathcote-fire-pit_p0520980?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=16140602058&gbraid=0AAAAADtbEB-WMgQDXToAtaFMxB2Srvl2C&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU77kwiqeyu65Rt8UgjiYblXb_W8YEH0GEyTQfKVPM2lBDA9OLQRlekaAkG_EALw_wcB
https://www.bunnings.com.au/custom-concrete-products-500-x-500-x-40mm-plain-paver_p3463489?store=4059&gclsrc=aw.ds&gad_source=1&gad_campaignid=23022021534&gbraid=0AAAAADtbEB8FvO35sdZipMXupxQnyrrSK&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU5zV_YH4tvUZRCkHSZsSAmuMlwBYrdE3FfFSNjg0vNimf2T9o2g11saAi8wEALw_wcB
https://www.bunnings.com.au/trojan-150mm-pointing-trowel_p0551194?store=4059&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB9-ccutQgHTrv3XnEQ4BllDJ&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU5OxnNbrX-4VyTwOIJs_FkWUZOUWlRRP5qxWh5Fhc30LAAZVM-r-nwaAqEtEALw_wcB
https://www.bunnings.com.au/gerni-3600-1810psi-1500w-high-pressure-washer_p0235516
https://www.bunnings.com.au/stanley-1200mm-high-impact-abs-resin-spirit-level_p5660383
https://www.bunnings.com.au/qep-24-universal-adhesive-mixer_p0443011
https://www.bunnings.com.au/trojan-14t-rake-timber-handle_p0684988?store=4059&gclsrc=aw.ds&gad_source=1&gad_campaignid=23022021534&gbraid=0AAAAADtbEB8FvO35sdZipMXupxQnyrrSK&gclid=Cj0KCQjwg5zTBhCLARIsAP2AFU5vsseDcFrCpzv8SQw2v_Ly_I03joBVd5hG5zjIJY6OjN_WNgKjI6EaAny5EALw_wcB
To start for best adhesion we pressure washed the slab in the morning then measured up length of sides we needed pavers for, we wrote a supplies list then we then went to Bunnings to collect all items from the lists above.
When we returned we then dry fit the pavers around the border. After dry fitting the pavers we then mixed up the Davco Tile adhesive. We used a bucket and ryobi drill and mixing attachment to make this easy. We then used the pointing trowel to put this on the concrete and the pavers one by one then smoothed both sections with the notched trowel. We completed this in about an hour using a level as we went to keep everything level.
This then set overnight and the next morning we pressure washed the extra adhesive off the pavers and also use the attachments to actually push out some grout at the bottom of some joints to act as drainage holes. This is very important so water trapped can drain away.
We then poured the drainage gravel bags x10 into the area smoothing this out with the back of a metal rake, then added the 10x bags of decomposed granite on top smoothing this out with the back of a metal rake and flattening with a shovel.
We then placed a large paver we had at home already but easily available at Bunnings (I have linked similar above) and our fire pit on top (also one we had at home but available at Bunnings). We then added our armchairs and filled the fire pit up with wood to relax and enjoy our weekend project!
Welcome to the Bunnings Workshop community @justinmurphy375. It's fantastic to have you join us, and many thanks for sharing your fire pit project.
You've made excellent use of an existing concrete slab to create a clean, inviting outdoor space. The charcoal paver border gives the area a really neat finish, and the combination of drainage gravel and decomposed granite creates a practical, low-maintenance surface that suits the fire pit perfectly. It's also great to see you included drainage holes between some of the pavers to help prevent water from becoming trapped beneath the surface.
I imagine you'll be spending plenty of evenings out there enjoying a fire with family and friends.
Thanks again for sharing your project, and we look forward to seeing what you tackle next.
