how do I change some or all of my downlights to smart lights with sensor and timer ability
Hello @KazElliott
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your downlights.
If your downlights are controlled by standard wall switches, the easiest Bunnings solution is to replace the existing light switches with DETA Grid Connect Smart Switches. Please make sure to speak to your electrician before you make any purchases. This is to make sure that they are compatible with your current downlight set-up.
These connect directly to your home Wi-Fi (no hub required) and let you control your lights from the Grid Connect app, as well as Google Assistant and Amazon Alexa. You can also create schedules, timers and scenes.
A few things to keep in mind:
As these are fixed 240V electrical devices, installation or replacement of the switch or the lights needs be carried out by a licensed electrician.
