Hi, I have a L shape kitchen and looking for a laminate bench top which will look the same in both directions when connected together for a L shape kitchen.
What would you recommend?
Thanks
Hello @shaun545
My best advice is to look at benchtops that have a neutral pattern that is non directional. A good example are the https://www.bunnings.com.au/kaboodle-2400-x-600-x-38mm-torrone-square-edge-benchtop_p0825786 and the https://www.bunnings.com.au/kaboodle-2400x600x38mm-almond-brittle-laminate-benchtop_p2669815 . These benchtops have static patterns which means that no matter what direction you put them in they will look the same as a whole.
There are other patterns available and I suggest start looking at the Kaboodle Benchtop series and go from there. There is also Think benchtops that have a variety of neutral patterned benchtops. I also recommend visiting your local store and speaking to the store's kitchen specialist, they will be able to show you samples of the benchtops available.
