Found an old desk on the sidewalk, asked permission to take! Wanted to up-cycle to make it a lovely furniture piece. After cutting the lower legs off, I found I could make two consol tables out this one old fashion desk. Was a little challenging but fun to get it done. Both pieces look OK!
40x40dressed pine- legs. 225 X 2400 pine, cut in half, dowel joint/liquid nails, clamped overnight. Screws, sandpaper, sample pots, Feast Watson hard wax. Marble/gold drawer pull
I use. Ozito: 3 drills,1X for drill bit. 1X for screw bit 1X for counter sink bit. 2 X sanders. Bench Drop saw. Set of Chisels. Paint brushes and rollers.
Wiped the dirty desk clean. Cut the ‘turned’ legs off at the top. attached new square legs to match, using dowel joints and liquid nails. Added cross bars to the bottom for extra strength. A lot of sanding, especially the top. Painted the lower leaving the top and drawer natural with hard wax. Instead of discarding the lower section, I decided to transform it into a more modern console table by painting it a pretty sea green and leaving the top natural with hard wax.
