This is a melaleuca timber dining table with a resin pour and welded steel frame base. The resin pour is to resemble a creek with gold flake nuggets hidden in the resin.
Legs
- 50mm x 50mm RHS
- Dulux Metal Shield Satin Black paint
Table Top
- Natural edge timber slabs
- Diablo belt sanding paper 40 & 80 grit
- Diablo orbital sanding paper 120 - 400 grit
- Wet & dry sanding sheets 400 - 1200 grit
- Timber screws
- Deep pour resin (poured in 1cm layers)
- Feast & Watson Scandinavian Oil
Connecting Top & Legs
- M8 timber button head screws
Legs
- Ryobi metal drill set
- Ryobi step drill
- Makita drill
- MIG welder
- Makita angle grinder
- Makita cutting and grinding wheels
Table Top
- Makita belt sander
- Makita orbital sander
- Sanding pads
- Measuring cups and mixing paddles
- Lint free cloths
- Polishing/buffing wheel (to polish resin sections)
Connecting the Top & Legs
- Makita Drill
- Makita impact Driver
- Kanga drill bit extension & hex connector drill bit
- Button head screws
- Kanga 152mm impact driver bit
Legs
- Measure and cut leg components
- Weld metal legs to the desired shape
- Drill holes in steel to fix top to the legs
- Paint steel legs and leave to dry
- Step 2:
Table Top
- Sand timber surfaces for desired texture and feel
- Create frame for natural edge timber slabs and resin pour
- Use roof and gutter silicone to seal edges of section to pour, this prevents resin from running
- Pour first layer of resin
- Place features on dried resin layer
- Pour layer after layer till desired height
- Sand and polish resin once dried
- Step 3:
Connect Top & Legs
- Pre-drill holes in timber, be sure to align the holes with the holes made on the steel legs
- Screw legs to timber top
