Hey everyone,
I'm wondering if it's possible to fix the wooden stairs that have some surface damage. I'm not looking to replace them, but I'm hoping to find a way to fill, polish, or paint them if possible.
Hi @waqarrasheed,
Your steps use decking boards, and they look a bit weathered and worn, but as long as they are still solid, there's plenty of life left in them.
The process to restoring them is the same as with a weathered deck, which is to sand it back, clean it and then coat it.
I'd suggest you check out https://www.bunnings.com.au/diy-advice/diy-skills/sanding/how-to-sand-a-deck , https://www.bunnings.com.au/diy-advice/building-construction/decking/how-to-clean-a-deck and https://www.bunnings.com.au/diy-advice/building-construction/decking/how-to-oil-your-deck for some guidance on the restoration process.
If you do not wish to use an oil, there are also stains and paints. If you'd like to alter the colour a bit, check out https://www.bunnings.com.au/diy-advice/diy-skills/painting/how-to-stain-a-deck and https://www.bunnings.com.au/diy-advice/building-construction/decking/how-to-paint-a-deck for some guidance.
Have a read through these articles and if you have further questions, please don't hesitate to ask.
