I’ve been learning lots from the many deck posts but I’m still a bit stuck on how many posts I need.
The deck is an extension to link a current deck to a new sauna. The current deck is a bit odd- brick piers on concrete footings with 100x50 bearers and 100x50 joists.
The decking I build will be 3m long and about 1800wide on one side then cuts in a little to be 1600wide for the last 1200 to meet the existing deck around a garden bed.
I’d like to have the fewest posts necessary, and keep airflow under the deck. Here’s a couple of options I can see:
1. traditional joists on bearers, using 140x45 bearers and 90x45 joists (all I saw in Bunnings that was structural was h3- is that correct? I’d be happy to use structural h4 for both). Bearers spaced and posts at ends and in middle. The down side is i think this needs three rows of bearers. And it goes below 150mm gap for airflow. So not preferable.
2. A single layer deck, with 140mm x 45mm for joists and bearers (is it a joists and rim joists/trim boards?) Could I just do that, and would that mean I can just have 6 posts? I’d put the posts in the corner and then either in the middle of the bearer or at 1800 to match the end of the sauna deck.
I've read quite a few posts and tried to include those into my design; I'd love to double check a couple of things on where I ended up.
- If I use posts into concrete footings, are my designs ok with span tables? I find it hard to understand span allowances for single layer deck.
- As above, if I go with single layer deck and I use 140x45 h3 mpg10 timber, for joists and the edge (trim board?) can I can reduce the number of footings and posts to 6, and should I simply have them in the corners and then halfway down each side (or should I put this at 1800?) my plan was basically to make the whole thing 1600 x3000 and then address the gap to the 1800wide deck with joists on joist hangers to between the two ledger boards (or the screws I saw you mention are options elsewhere)
- How far down do the concrete footings need to be- minimum? I'd use a stirrup into concrete and 90x90 h4 posts.
- In a single layer with rim joists like this do you just notch them into the post on both sides? Or is it better to out the post back from the absolute corner and support the long edge (what would usually be the bearer/what the joists will hang off)?
Sorry for all the long winded detail and questions. The 'doing' side doesn't really faze me- it's the planning. I have not ever had to design footings or structural frame, or set a post. I have helped labour and done what I'm told.
