how to install gas spring in expanded state with ends in different directions on king bed with gas lift
sloane king bed frame
Hi @sumeeth,
I'd be at best guessing without knowing how the bed is constructed, however it does seem like there should be a bracket or something similar attached to the bed base that the metal rod sits in, with the loop at the top screwed into the bed frame.
What do the instructions say?
Unfortunately, as it is not one of our products, I do not have access to the instructions. It is likely best that you contact the bed's manufacturer for assistance.
Hi @JacobZ
Thanks for looking into this issue
Found out that the strut is a bit faulty it's ends don't align with the holes. Fixed by bending the silver side with a pliers until it fitted nicely.
Many thanks for updating us on your success @sumeeth.
