Hello,
I was removing silicon with stainless scraper on bathroom tile but it left grey mark on the tile. Please see attached photo. Please advise how I can remove the mark from tile.
Thanks.
Hi @acimeliler,
The grey mark is likely metal transferred from the stainless-steel scraper rather than a scratch in the tile itself.
Start by applying a small amount of cream cleanser to a damp, non-scratch cleaning pad and gently rubbing the mark in a circular motion. A damp melamine sponge may also help.
You can continue removing the silicone, using this method as necessary. If you are having trouble removing the rest of the silicone, https://www.bunnings.com.au/selleys-sealant-remover-375g_p0828840 can help to soften it up for removal.
Hi Jacob,
I have Bar Keepers Friend 595g Cleanser & Polish Powder. Can I use Bar Keepers instead of cream cleanser? Which is the most effective?
Thank.
Bar Keepers Friend can be used on many glazed ceramic tiles, but the powder is more abrasive than a cream cleanser and may dull or scratch some finishes if rubbed too firmly. I’d recommend using the cream cleanser first, as it is the gentler option.
Whichever product you use, test it on an inconspicuous area first and apply it with a soft cloth or non-scratch sponge. Avoid using a scourer.
Hi @acimeliler
If you already have Bar Keepers Friend on hand, you can certainly give it a go. It is an abrasive cleaner, so test it on a small, inconspicuous section of tile first to ensure it doesn’t scratch or dull the glaze. Use a soft, damp cloth, apply minimal pressure and rinse the area thoroughly afterwards. If it does not assist, you can move on to Jacob's other suggestions.
hi @acimeliler
Believe it or not, I would try Silvo Silver polish. It is a very fine abrasive and can be used to polish scratches out of glass. The best thing is called Jewelers Rouge and is used for polishing gem stones but it is hard to get. I learned this trick 55 years ago when I spent some time with a company that refurbished TV sets and rather than replace a scratched screen they would polish the scratch out if it wasn't too bad.
