Hey Team,
I have a timber extension that was built with thin wood panelling as walls (non-bearing, simply filling the gaps in the timber frame). Some of the panels are starting to get damaged due to exposure to the rain. I'd like to replace them, and take the opportunity to do a better job than the original build (if I can manage!).
The panels are probably 6 or 7 mm thick, so thin that some tapping on a sodden area produced a hole (taped over as you can see in the pics - black tape inside; silver tape outside).
The frame around them seems solid enough, albeit there's a small leak somewhere: I can see water slowly dripping inside on very rainy days. I also had to patch some rotten wood on the outer timber frame (black spot in the exterior photo, at the bottom of the timber frame - that's bitumen).
Question 1: if I where to simply replace the panels, keeping the same design, what could I use? I'm definitely open to some texture or even a stacked washboards look rather than the fairly plain panels I have.
Question 2: if I wanted to upgrade the setup, would it make sense to stick some insulation in, sandwiched between an exterior and an interior panel? The frame is relatively thick.
Thanks in advance!
Andrew
