Hi
I have a 90mm storm water T piece that is leaking from the joins. The original T piece and connections was cut out as it was damaged and a new T piece, pipe and 3 slip coupling used in the replacement\repair. It was suspected that there was still a leak, so the connections have been exposed again and it was found that water is dripping out from the end of the couplings (away from the join, on all 3). One leak is dripping at approx 1 drop every second, the other 2 are a lot less than this.
What is the best way to fix this?
