I'm looking to replace some internal doors to the original (1990s) steel frames.
We currently have hollow core doors and they're falling apart and, with a new baby just arrived we'd like to avoid waking our older child. We're considering a solicore door like the Hume SCX1 as its sound properties are better.
All of the doors in our house are currently hollow core doors in steel frames. They only have two hinges and all of the newer doors we've looked at are heavier and require three.
I've never looked into hinges on steel door frames and I'm not really sure where to start with adding or replacing them. The existing hinges look fine - a bit dirty but fine otherwise. I can't see any way to remove the existing hinges, and they're attached inside the frame.
Would I be best to use an angle grinder to cut out another slice in the frame, and rivet a new hinge in somehow? Or use a flush mount the hinge and use steel screws, but would this cause an issue with the existing hinges because of the gap difference?
