Hi everyone,
I’m looking for some ideas to insect-proof the ventilation slot above the fixed pane of my older timber window.
The opening is approximately 40 mm high and 870 mm wide. It seems to be an intentional ventilation opening, so I’d like to keep the airflow while preventing insects from getting in.
The first photo shows the top right corner from inside, and the second photo shows the top left corner from outside.
My initial thought was to fit flyscreen mesh, but I’d like the solution to be sturdy, neat and removable so I can easily replace the mesh in the future if needed.
One limitation is that the screen will need to be installed from the outside, as there’s a bathtub directly behind the window that blocks access from inside.
Has anyone done something similar, or can recommend a good way to build or install a removable flyscreen panel for this type of opening? I’m open to DIY-friendly products as well as professional solutions if there’s a better approach.
Thanks in advance!
