Hi, we have just had our outdoor patio re-tiled with new tiles after we had a significant water leak and quite a large area of tiles were destroyed trying to locate the leak. The tiler has done a good job from what I can tell, but I wanted to check about his use of silicon around the edges (pretty sure it's silicon by the feel of it).
Initially I had asked if he could use silicon or caulk around the edges of the tiles where they meet the brick wall, because I read that was a good idea (mainly from AI search results TBH).
But, then I talked to him later and he suggested grout normally looks better and the also the previous tiles had grout on the edges. So, I said to go with grout instead.
But now that the job has been completed, I can see he used silicon… probably he forgot the last conversation.
I've searched on this more, and there seem to be mixed views on grout vs silicon for outdoor tiles against brick.
Just wanted to get another opinion (and hopefully reassurance) that what he's done is ok. I do think grout would have looked slightly better, but the silicon is colour matched and doesn't look bad (see photo below).
I guess I just want to check if this is something worth raising, or if I should just let it go.
Cheers,
Stephen
