Hi everyone just confirming the Mondella shower screen will 100% work with the Mondella base? Thank you
https://www.bunnings.com.au/mondella-900mm-x-900mm-3-lip-rear-outlet-shower-base_p0332299 https://www.bunnings.com.au/875-x-2000mm-black-matte-semi-frameless-shower-screen_p0826219
Hello @michaeli
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Mondella shower.
From what I recall the Mondella 875 x 2000mm Black Matte Semi Frameless Shower Screen is designed to fit standard 900 x 900mm shower bases, specifically matching standard lips on base units like the Mondella 900mm 3 Lip Centre Outlet Shower Base or Mondella 900mm 3 Lip Rear Outlet Shower Base. But just to be sure I've sent a query to Mondella to make sure that they are compatible. As soon as we get confirmation, we'll let you know.
Thank you for your patience.
Thank you for your patience. The Mondella team have confirmed that the shower base I/N 0332299 is compatible with the shower screen I/N0826219.
