Hi there,
I’ve recently had a 9x6m Titan steel shed built for storage / workshop / home gym use. 8mm reflective foam installed on the roof. Walls are uninsulated. Steel frame is 75mm deep on 600mm centres.
I want to insulate the walls and probably add some more to the roof to make the space a bit more comfortable in the summer.
After an extensive search of YouTube and this blog, I’ve found some great advice on how to do this. For the roof, I’m planning to add some kind of foil board, straight on top of the reflective foam - either screw directly into the steel roof supports or add a timber frame first. What’s best practice here?
For the walls - I’d like to add earthwool between the steel supports, then OSB over the top. I understand that I need to install a vapour barrier directly onto the outer steel shell first, to control condensation before I add the wool. I’ve seen various advice saying to cut plastic sheet or vapour barrier sheet and attach to the frame, but I haven’t found explicit advice on how to do this for a metal framed shed. I am worried that I won’t get a proper seal with the vapour barrier and moisture will move into my wool insulation. Please can you give some guidance on how exactly this should be done?
I should have thought ahead and had the walls wrapped in vapour barrier before the outer shell went on… but here we are. Hindsight is a great thing!
Thanks so much.
