Hi Bunnings Braintrust,
(Sorry in advance, this will be long winded, as I want to include all of the relevant facts)
We have some unsafe/impractical steps at our front door. (AI cleanup deleted the side windows)
Plan is to build over steps with a new landing & box steps.
Most of the area is undercover. It faces South & we had some rare southerly rain in this photo.
I did a plan on the Bunnings deck builder & although the design is good, but the framing left us bemused! I donโt think the poor planner knew what to do ๐
Due to the irregular shape & current steps (which we want to avoid removing) working out a plan has taken much research & redraws,
The end plan will be 400mm high
Top step will be done separately with 70x35mm H3 laid on its side with 3mm packers underneath, attached with angle brackets. This will then be attached to the framework of the rest of the deck, similar to this reference pic.
MATERIALS TO BE USED-
CONCRETE STEP
70x35 H3 treated pine (laid on its side)
PACKERS
ANGLE BRACKETS
LANDING & BOX STEPS
DECKING โ 19x83mm Stringybark decking
JOISTS - 140x45mm H3 Treated Pine
JOIST TAPE
BEAMS โ Doubled up 140x45mm H3 Treated Pine
POSTS โ 100x100mm H3 Treated Pine
POST SUPPORTS - Maxi Metals Galvanised Bolt Down Post Support
RISERS - 130x19mm blackbutt decking standard kd
JOIST HANGERS
SKEW JOIST HANGERS x5 โ (for step angle) Simpson Strong-Tieยฎ LSSR Slopeable & Skewable Rafter Hanger ZMAXยฎ Galvanised
โโโโโโโโโโโ-
DESIGN NOTES โ
Diagonal decking parallel to front door
Joists @ 10 โ OC
Single picture frame
Skirting โ Stacked stone on STONESHEET backing (allowance will be made for ventilation)
QUESTION
One particular question โ Free-standing deck or joined to house?
This is the current plan.
We would appreciate feedback/suggestions please.
