I have 2 questions.
1. Deep gap along the driveway between the concrete color and concrete exterior wall. A lot of weeds are in it. How do I fill the gap?
2. Some of the concrete floor chipped like in the photo. How do I fix it?
Many thanks!
Hello @Cocoabrowny
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the gap between your concrete path and the wall.
I suggest cleaning the gap by removing the weeds that have started to grow. I then suggest using https://www.bunnings.com.au/moroday-15mm-x-25m-mgf1-gap-filler-rod_p1070478 to cover the gap. Push the foam rod at least 5mm deep past the surface. To seal the gap, I recommend using https://www.bunnings.com.au/sika-300ml-concrete-grey-sikaflex-11fc-purform_p0628962 . In regard to the chipped section, you can cover it with extra Sikaflex.
Please remember to wear personal protection such as gloves, goggles and a mask.
Smallish gap between exterior rendered walls and concrete floor. What paintable fillers do you recommend? Thanks
