dear community,
we have an old CLICK bathroom ceiling exhaust fan (from 5~10 years ago) that no longer works.
we are hoping to find a replacement without adjusting the cutout size if possible.
as per below picture, inner frame is 265mm, fan size is 230mm and plastic grille is 323 mm in diameter.
we can also measure the outer metal round frame if required.
so far we have considered:
- IXL 250mm White Eco Ventflo Exhaust Fan (cutout diameter 295mm)
- IXL 250mm Ventflo Exhaust Fan (cutout diameter 290mm) much cheaper without IP rating
- IXL 200mm White Eco Ventflo Exhaust Fan (cutout diameter 242mm)
our questions are:
- what size of bathroom ceiling exhaust fan should we purchase (eg. IXL 200mm vs 250mm)? we are also open to other brands as long as it fits without making any adjustment to the cutout size.
- should we remove the cotton-like material on the roof which can be seen through the cutout? we pulled out some thinking they are dust but seems like they are made of a different texture that need to be torn off or ripped off.
- if we cannot find a matching fan size, is it easier to repair / clean the existing CLICK bathroom ceiling exhaust fan, assuming its fan motor has not worn out.
- for bathroom exhaust fan with no ducting, is IXL a better brand than eg. Click, DETA, HPM, Arlec?
thank you so much for the kind assistance in advance.
