Good morning
Looking at plasterboarding a fully stripped bathroom in prep for waterproofing, plumbing, tiling etc.
Planning on using gyprock aquachek 10 mm thick for both ceiling and walls.
https://www.bunnings.com.au/gyprock-csr-3600-x-1200-x-10mm-4-32sqm-aquachek-plasterboard_p0732568
Should stud adhesive be used given that is a wet area?
The Gyprock instruction video also recommend putting 10mm spacer between floor and lower gyprock panel to allow for expansion.
Is this still the case for gyprock Aqua check?
(I believe when I stripped the bathroom the original plasterboard ran all the way to the bottom, beneath the tiles and subfloor?)
And how does that then work with waterproofing?
photos attached.
Thank you in advance.
Jan
