My wife wanted a media wall and was very specific as to what it was to look like, so being a good husband I drew a plan then drew it on the wall, worked out what materials I needed and went on a spending spree at Bunnings.
Approximately 6 weeks later the wall was finished and the room was repainted and my wife was very happy. Just to let you know I have no formal training and no trade background.
https://www.bunnings.com.au/90-x-35mm-framing-mgp10-untreated-pine-2-4m_p8030056
https://www.bunnings.com.au/9mm-mdf-panel-standard-2400-x-1200mm_p0590056
https://www.bunnings.com.au/paslode-75-x-3-75mm-2kg-bright-steel-bullet-head-nails-280-pack_p2360478
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive-3-pack_p1236505
https://www.bunnings.com.au/66-x-18mm-5-4m-white-moulding-pine-fj-primed-aus-colonial_p0020754
https://www.bunnings.com.au/easycraft-easylining-convex-30-primed-general-purpose-18mm-2700-x-170mm-mr-mdf-e0-primed-white_p0493241
https://www.bunnings.com.au/gyprock-csr-3000-x-1350mm-10mm-4-05sqm-plasterboard-re_p0730134
https://www.bunnings.com.au/gyprock-csr-2-25kg-less-mess-multi-purpose-joint-compound_p0173344
https://www.bunnings.com.au/gyprock-csr-75m-plasterboard-perforated-paper-jointing-tape_p0731017
https://www.bunnings.com.au/gyprock-csr-2700mm-rondo-17-90-mini-internal-angle_p0200877
https://www.bunnings.com.au/titan-6g-x-30mm-ph2-plasterboard-screw-500-pack_p0912041
https://www.bunnings.com.au/gyprock-csr-90mm-x-3600mm-cove-plaster-cornice_p0731300
https://www.bunnings.com.au/click-6w-70mm-cct-led-downlight-12-pack_p0516236
https://www.bunnings.com.au/taubmans-10l-tradex-white-flat-interior-ceiling-paint_p1540672
https://www.bunnings.com.au/taubmans-15l-white-low-sheen-endure-interior-walls-paint_p0024208
- Hammer
- Cordless drills
- Drop saw and stand
- Levels
- Gyprock flushing tools
- Sanding equipment
- Paint brushes and rollers.
Plan on paper what we actually want to end up with and how we want it to look including all measurements.
- Step 2:
Draw the layout on the wall, checking that the measurements are right and that we are happy with how it will end up.
- Step 3:
Start measuring and cutting the framework and fixing them into place, ensuring levels are correct.
- Step 4:
Get the electrical wiring done by a professional electrician and position all wiring ready for gyprocking.
- Step 5:
Install gyprock and angle trims to framework and cornice to the ceiling and MDF board to shelves (MDF because it is stronger for placing ornaments and such).
- Step 6:
Flush and the finish all gyprock, then sand to a smooth finish ready for painting.
- Step 7:
Cut and fit the Easycraft MDF panels to the sides and rear of the shelving areas.
- Step 8:
Paint everything from the top down, ceiling and cornice first, then walls and media wall, then the skirting board, lastly paint the MDF shelves with enamel paint (stronger paint to handle items being on it).
- Step 9:
Finally attach all power point sockets and other connectors to gyprock and insert down-lights into holes.
- Step 10:
All done.
- Help and inspiration:
[article footer]
More inspiration for your home
Bunnings Workshop member Wabi-sabi created a TV feature wall with illuminated niches using Gyprock and framing timber.
Community member SammJ103 transformed a plan living room wall into a built-in entertainment wall with VJ panels.
Get more inspiration from 20 living room makeover projects.
[article footer]
