Hello,
Water coming underneath fence from neighbour’s property every time it rains. It creates flash flooding in my backyard and washes away soil and escape from my property to neighbour’s property. I have raised this issue with neighbour but no action has been taken. What action should I take to stop water permanently.
Hello @Bingo2808
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the water coming under your fence.
One possible way to mitigate the incoming water into your area is to install a French drain that diverts the water outside your property. Please note that you will need the services of a licensed plumber as they will know how to properly and legally divert the water coming into your area. A French drain is a drainage system designed to redirect excess water away from an area. It consists of a perforated pipe laid in a gravel-filled trench, usually wrapped with drainage fabric to prevent soil from clogging it. Water filters through the gravel, enters the pipe, and is carried to a suitable drainage point.
If significantly heavier rainfall is anticipated, I would recommend consulting your plumber to determine whether installing two drainage pipes would be prudent to accommodate the increased volume of stormwater.
You'll need the following materials:
Please consult your plumber in regard to length and quantity before you purchase the materials. The surface can be covered in larger drain gravel such as the https://www.bunnings.com.au/ki-carma-20kg-10-20mm-drainage-gravel_p3460052 . I've placed a sample rendered image using AI to give you an example of what it would look like once the French drain is installed.
