This is my old ceiling that Im wondering the best way and product to use to patch it. I was looking at the gyprock patch product but not sure how best to tackle it. I know I'll need to scrape off the old flacky paint but Im more concerned around the details near the fan etc. https://www.bunnings.com.au/csr-420gm-gyprock-diy-one-patch-filler_p0633039?store=7380&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gclid=CjwKCAjwqJXUBhBNEiwA8BgG7vpThQI_vGMQOIsLU-uNCrCcBPoqmzsTIAFtVEjyYgC5oFBzQy6fcRoCkDoQAvD_BwE
Hello @tombot1974
Thank you for sharing your question about your flaking ceiling. Before you start sanding or chipping the flaking paint, I suggest having your ceiling tested for asbestos. If the test is positive, it will be necessary to engage the services of an asbestos removal specialist. If the test is negative, you can continue with your paint ceiling revamp.
On the condition that the test is negative, I suggest using a https://www.bunnings.com.au/monarch-expertech-20mm-flex-scraper-20mm_p0076382 for precision removal. You can use the same tool to spread the https://www.bunnings.com.au/csr-420gm-gyprock-diy-one-patch-filler_p0633039 . Especially if you are only putting it into small sections. It will be tedious work, so I would suggest doing it in sections rather than doing it all in one go. In this manner you will be able to work in the tight corners and prevent damaging any fine details.
Please remember to wear personal protection such as gloves, goggles and a mask.
