Can anyone tell me how to connect the existing antenna cable to the new wall socket. This is what I've got.
Hello @Jeanagh
Thank you for sharing your question about connecting your TV cable to the wall plug. I suggest having a quick look at this guide from Antsig - How to Install Twist-On F-Connector on Coaxial Cable. Once you have the F-connector attached to the cable you then attach the TV cable to the wall plug.
thank you Eric, i have done this but I'll cut it back and start again cause what I've got isn't working. All 've done is bend iit
Hi @Jeanagh,
If you're having trouble getting it to work, it is probably worth contacting an electrician or antenna installer for assistance. They should be able to connect things quickly and easily for you.
I'll have a go first cause I can't really afford the $$
