How do i select the best protective spray for outside split aircon virtually new, I live near beach
Just want recommended proctective product
Hi @Ian21,
I'd suggest having a chat with the manufacturer of your air conditioner about suitable protection from salt air. There are specialised polymer-based coatings designed to protect air-conditioning components in coastal environments; however, these are typically applied by the manufacturer and aren't really retail products that you would apply yourself.
I'd then recommend contacting a local HVAC technician. Being in a coastal environment, a local technician should be familiar with the effects of salt air and able to advise on the best method of protecting your particular unit.
In the meantime, washing the outdoor unit down with fresh water every month or so can help remove salt deposits and reduce their build-up. Just make sure the unit is switched off and follow the manufacturer's cleaning instructions.
Also, installing protection from the prevailing coastal winds can help. Options like this https://www.bunnings.com.au/protectoral-1000-x-830-x-495mm-monument-steel-slat-airconditioner-cover_p0676406 , or something custom like @homeinmelbourne's Air conditioner condenser screen could certainly help to offer additional protection. You'd just want to double check with the manufacturer that anything intended to cover the condenser is in line with the unit's ventilation and setback requirements.
