Hi there I stripped back and sanded my window sill, but couldn't get it to even levels (ie some areas paint stripped back to whag looks like 2 colours ago). I used filler to patch the lower levels, sanded and primed, but it clearly wasn't the right thing to do.
From other questions it seems a skim coat would be an easier remedy (I was wary that the older layers of paint might have lead in them, so am not keen to sand deeply again).
Questions:
- Sand the primer off again first? Or can I skim coat over the primer?
- I've got Gyprock multi purpose joint compound from other jobs. Could I use that or do I need to buy the topping compound? (They seem to come in large quantities that you end up with left overs that never get used).
Thanks
Trudy
