I need to replace tap button as per photos attached. I found this https://www.bunnings.com.au/kinetic-5mm-and-10mm-gold-hot-and-cold-tap-buttons-2-pairs_p0135591 but I am not quite sure if they are the same (correct items). The lower part doesn't seem to be the same as mine. Please advise. Thank you.
Hi @otnimus1,
I can't say I have seen replacement tap buttons that have a thread like that before. You might still be able to use the https://www.bunnings.com.au/kinetic-5mm-and-10mm-gold-hot-and-cold-tap-buttons-2-pairs_p0135591 , however, as far as I can tell, they do not have that thread. I'd suggest you bring your tap buttons in store with you to compare sizing. If they match in terms of size, then you could just use a bit of super glue to hold the buttons in place.
In saying this, if you did need to remove them again, it could make it tricky if you've used glue. If you didn't want to deal with that issue in the future, you might consider just replacing the tap handles with something like these https://www.bunnings.com.au/shaw-mason-ivory-universal-multi-fit-tap-handles-pair_p5001663 . When you consider the cost of the tap buttons and glue, it would work out pretty close in terms of price.
Hi @JacobZ thank you for your response. I think it's a good idea to replace the whole handle. Would you think the one you linked to will match like for like on my tap?
And what's the difference to this which has identical picture: https://www.bunnings.com.au/shaw-mason-ivory-universal-multi-fit-tap-handles-pair_p0595187
These tap handles are designed to fit most standard tap spindles, and they come with multifit adapters, so there's a very good chance it will fit, but ultimately, it comes down to what kind of spindle is underneath the existing tap handles. I'd say the best thing you can do is remove your existing tap handles and take them in store to compare. If you purchase new tap handles and find they do not fit your spindles, you may need to swap out the spindles for compatible ones. Keep in mind you can always return products as long as they are kept in saleable condition. Keep your receipt too, it makes the process easier if any returns become necessary.
They are essentially the same product; they have likely just changed their packaging or made a very small update and are selling through the last of the old stock.
