I cannot remove spindle to be able to replace Bailey privacy door handles
Hi @spanna219,
If you have a photo of your door handle showing the spindle that you can upload, this could certainly help us to diagnose the issue and give you advice. Let me know if you need a hand with this.
You might like to have a look at the discussion which discusses a few different similar situations.
Oftentimes, there is a small O-ring on one side of the spindle which can be tough to spot. If you look at the base of the spindle on both sides of the door, can you see a small O-ring? If so, a pick tool like one from this https://www.bunnings.com.au/craftright-4-piece-hook-and-pick-set_p6120228?store=7369&gclsrc=aw.ds&gad_source=1&gad_campaignid=20422937447&gclid=EAIaIQobChMIy7yp8ZHFlgMVYfU8Ah0CBjVoEAQYASABEgI4EvD_BwE can help to remove it.
Sometimes the spindle can have a hole at the top with a concealed hex fitting inside that requires an allen key to remove it.
Otherwise, have a look on the latch mechanism at the base of the spindle to see if there is a button, or anything that seems like it can move. There may be a hidden mechanism that requires pressing or turning to release the spindle.
Let me know what you find.
Thanks Jacob
I found the rubber ring and removal allowed me to remove the spindle and mechanism. The replacement doesn’t have a rubber ring. But a button. Hopefully will not have to replace this one as it appears to be more robust.
