Hi community, would love some advice on the following.
- Fill gap between entry way and door sill that has sub floor
- Best way to pack out and trim left and right sides of where I removed bricks as this was a window.
- Damp Proof / Inject Lime mortar?
This room was an old sleep out which was bricked up well and truly before I purchased it but entry was through the main house.
This was a window which I converted quite a few years back to French, parliament hinged doors. The doors have a solid jarrah frame, the etched glass was already 6.5mm but has been laminated for safety. They are being stripped and redone.
Bricked up with red kiln fired bricks, cavity (can’t see a damp proof course), but perhaps the subfloors and the other vents allow for that?
Also, in the process of stripping the paint. It’s a process and yes, it’s lead paint and I believe should never have been painted as those bricks should breathe? Will leave the render.
Sub floor of 700mm - Inspection Points / Access
Only where the gap is where I removed a floorboard and quarter round to re-do the door sill, paint doors, reinforce underneath traffic area.
Limited access as no inspection point other than one where the floorboards meet (well don’t meet) I made under the kitchen bench and one which has now been walled off to the main house.
Used my go pro on a piece of conduit and there is no sign of pest or rodent activity / treated anyway. No sign of rising damp but still wonder if I should do something about damp proofing?
Jarrah joists and bearers still look in great condition.
Mid doorway sits exactly where the middle bearer is. No bounce etc.
Questions and advice please:
- Since everything is getting it's summer body back, can I please have suggestions of first priority to close the entry way gap. I originally packed out with off cuts of jarrah and sistered the bearer. And put a length of 19 x 135 jarrah and quarter round on top. Has been great for 10 years. No photos of the layout unfortunately.
- Have never used plastic shims.
- Do I need more flashing?
- Is it ok to completely fill the gap (not the full subfloor gap), but under the door sill.
- More sistering?
- Fill gaps left and right of doors.
- Will obviously put trim back, but do I need damp proof? If so, what?
- Was thinking backing rods? and or expandable foam like HB Fuller Firesound. Have never used this one before, but do know expandable foam and I are only just becoming friends.
Thank you in advance. Hope this makes a semblance of sense.
Look forward to hearing back and thank you.
The Curious Swan
