Hi Everyone,
I am currently renovating my bathroom which has rendered brick walls and I am planning on waterproofing it using Crommelin undertile waterproofing membrane. I assume the current render is a cement based render, but when removing the old tiles, some chunks of render fell off, so I will have to touch it up and I was planning on using acrylic render to do so. Now, here's my questions:
- Can the Crommelin membrane be applied on Acrylic render? The specification sheet mentions cement render, but not sure if it's compatible with both.
- The current render has a few 6mm drill holes. What's the best approach to waterproof? Fill them with Crommelin bond breaker sealant and then apply the membrane as usual?
Thanks in advance for your help.
