Hi all,
I've got a timber pergola attached to the house (approx. 20 years old, exact age unknown) with a wisteria trained over it. One of the main bearers that supports the rafters has rotted badly where it meets the post — the end grain has gone soft and dark, and when I pushed up on it, the whole beam moved. It's clearly not properly fixed to the post anymore. Photos attached showing the general pergola, the joint from a couple of angles, and a close-up of the rot.
A few questions for anyone who's dealt with this before:
- Is this the kind of rot that can be cut back and repaired with a bracket, or does the whole beam need replacing?
- If I need to sister a new piece of timber alongside the rotten section (rather than replacing the whole beam), what's a sensible overlap length and bolt spacing?
- Can this be temporarily propped safely while I sort out a proper fix, or does it need to come down straight away?
- If the beam does need to come out entirely for a section, will the rest of the pergola still hold its load, or does removing one bearer risk the whole frame?
- The post and other beams nearby have similar staining/rot starting at the joints (not yet as bad) — is this something to fix one joint at a time or treat as a whole-structure issue?
Not looking to hire someone yet — trying to figure out if this is a DIY weekend job or something that needs a carpenter to look at properly first. Any advice on brackets/hardware, or things I should check before I touch it, would be appreciated.
Thanks!
Mark
