I have a spot of my brick wall that got chipped and render join damaged. What do I need to do in order to repair this?
Hello @Naidoo021
Thank you for sharing the photo of your chipped brick wall. I propose using https://www.bunnings.com.au/dingo-fast-set-mortar-3kg_p0760518 in combination with a https://www.bunnings.com.au/craftright-150mm-pointing-trowel_p0924471 .
I suggest cleaning the chipped corner and remove all the loose plastic and debris. Once the spot is clean mix a small batch of the mortar to sit into the damaged section. Do not mix it too soft or too hard as it must be strong enough to hold onto surface of the damages section. Do not over fill the damage, your goal is to have it at the same level as the wall. Give the patch five minutes to settle and then use a damp sponge on the corner to create a rounded profile the same as you have now. I recommend using a used toothbrush to stipple the surface to make it blend in with the wall. Allow the patch to totally cure before you paint the surface.
Please remember to wear personal protection such as gloves and goggles.
