Hi, I have a leak from our balcony, the old owners have recently painted over the damage but its quite visible there is an issue. Would I take out the grout & old sealant from in & around the tiles above & replace with new or how would I go about fixing this leak. Thank you.
Hi @Trev2,
Unfortunately, if water is leaking through a tiled balcony, the issue is unlikely to be the grout itself. The waterproofing membrane beneath the tiles is what should be preventing water from entering the structure, so a leak generally indicates that the waterproofing system has failed somewhere.
Replacing or repairing the grout might reduce the amount of water getting through and could appear to fix the problem temporarily, but it won't address the underlying cause of the leak.
I'd recommend having a leak detection specialist inspect the balcony to determine exactly where the water is getting in. From there, you'll likely need to speak with a professional waterproofer about the appropriate repair.
Unfortunately, this is unlikely to be a simple regrouting job. Depending on what the inspection finds, the tiles may need to be removed so the failed waterproofing membrane can be replaced and then the tiles reinstated.
