What product can I use to clean my deck? Doesn’t need a new coat. It’s been stained with Intergrain Ultradeck. Thank you.
Hi @Diana06 ,
You might like to start by having a read through https://www.bunnings.com.au/diy-advice/building-construction/decking/how-to-clean-a-deck and https://www.bunnings.com.au/diy-advice/building-construction/decking/how-to-maintain-a-deck for some general guidance.
As the existing UltraDeck coating is still in good condition, there's no need to use a coating remover or do anything particularly aggressive. A good clean with a timber cleaner and a scrub should be all that's required.
I'd recommend using https://www.bunnings.com.au/cabot-s-1l-exterior-cleaner_p0916143 alongside a https://www.bunnings.com.au/oates-long-handle-deck-scrub-brush_p4460246 . Once you've given it a good scrub, you can hose it off with clean water.
This https://www.bunnings.com.au/cabot-s-15l-deck-hand-bucket_p1661947 would also be handy for mixing your cleaning solution with water and then applying it with your scrubbing brush.
