This door handle will not lock properly. I think there is something faulty with the mechanism inside. It unlocks but it will not lock - it usually takes about ten goes before it will finally lock. I can either replace it or attempt to fix what may be wrong with it?
If it needs replacing, which handle and lock system would you recommend?
Thank you.
