hi all, i want to change the whole tap wanted to know what size i need to get. And is this an easy diy job? Thanks.
Hello @andrewong
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your garden tap.
Please note that plumbing work needs to be carried out by a licensed professional for safety and compliance.
Your garden tap is soldered onto a copper pipe, and any modification or rearrangement of pipe work is considered regulated plumbing work and will need to be carried out by a licensed plumber. I therefore suggest engaging the services of a plumber to replace your garden tap.
It is difficult to tell what garden tap size you will need but suffice to say that it is a wall mounted unit. The store does stock something similar looking such as the Kinetic 20mm Brass Back Plated Tap, but I would consult your plumber before you make any purchase to make sure that it is compatible with your existing tap.
@EricL okay noted. Ill try to change the tap valve to a new one, since i found out there a little chip on the side, might be the cause of the leaks as well. If it still doesnt stop after changing. Then ill contact a plumber to do so. Cheers.
