I have just set up a home garden drip irrigation system. There is a leakage I cannot fix. The main 19mm poly pipe runs downslope to a big planter box about 0.8 metre tall. For water to reach into the box, there is a tee fitting at ground level leading a poly pipe segment vertically up against the exterior wall, then an elbow fitting with a horizontal pipe segment and another elbow taking the pipe vertically down. Water seeps out at the first elbow, as marked in the photos attached. Please advise. Thank you.
