I'm looking at replacing my old 54cm freestanding hob and rangehood. The hob is an easy replacement as it's just plugged into a socket in the back. The rangehood I'm less sure of - it is plugged in as well (see pics) but the cord comes through a small hole in the shelf above the rangehood.
Am I likely to be able to DIY install the rangehood (total beginner with tools), or does this require the help of a cabinetmaker? I'm also not sure if this might have other electrical wiring that needs to be hardwired in by an electrician - any tips from those familiar with 80s house setups? Thanks.
Hi @kayara,
While both appliances appear to have plug-in connections, I would err on the side of caution here, particularly as you've mentioned that you're a total beginner with tools.
Before replacing the freestanding cooker, I'd recommend having an electrician confirm exactly how the existing unit is connected and that the electrical supply and outlet are suitable for the replacement appliance. Depending on the power requirements of the replacement cooker, it may require a higher-amperage outlet and dedicated circuit rather than a standard 10A power point. If any changes to the outlet, circuit or fixed wiring are required, this would need to be handled by a licensed electrician. A visible plug doesn't necessarily tell us everything about the existing installation or the requirements of the new cooker.
With the rangehood, there will also be some physical installation involved, including removing the existing unit, mounting the replacement securely and potentially modifying the cabinetry or ducting depending on the new model. The power cord passing through the shelf will complicate removal and installation, as you can't modify the cord, plug or electrical connection yourself.
Considering you're replacing both appliances, I think the safest approach would be to engage an electrician. Depending on the rangehood you select and whether the cabinetry needs modification, you may also need assistance from a cabinetmaker or handyperson.
If you could give some details about the rangehood you were hoping to use, we could certainly have a look at the requirements to see what is possible, however you would almost certainly need the assistance of an electrician with the installation unless you were happy to cut a much larger hole in the cabinetry for the plug to pass through.
Thanks Jacob. I wanted to see if this was more straightforward than I originally thought, so your feedback is helpful. I think in this case I will just have to go ahead and engage an electrician as the power requirements etc. aren't clear to me so I'd rather play it safe with this kind of thing.
