Marrying a new outdoor entertaining area with our old verandah was a great project.
Working hard at perfecting gaps and mitre joints for my first time.
I fear I over-engineered this one, with more stumps, concrete and bracing then the existing house.
Here's a high-level list of the materials I used.
I already had a big bucket of stainless deck screws. I used stainless as I'm near the ocean and it destroys all metal.
First job of any D.I.Y. build is to consult with your manager.
We had to measure up, prepare to remove the clothesline and the old garden bed.
- Step 2:
The trickiest part of a build like this when you're not a pro is marrying the existing structure to the new structure. So I did a lot of "measure twice, cut once…"
The stump digging revealed a pipe that needed to be moved.
- Step 3:
Post holes dug, roughly 800 deep, 400 out the top as the existing structure was quite close to the ground. I used a little gravel in the bottom of the post holes and I painted the ends of the posts where they would be in contact with soil. I also coated any surface that I'd cut to help with the H4 treatment protection.
After all of the posts were in place, I rolled out and pinned down weed mat to help stop weeds and grass growing up under the deck.
- Step 4:
Bearers bolted into the stumps, I cut out little shelves for the bearers to sit in and used galvinised bolts to secure them. Then I set the joists in their rough positions to make sure everything was in its right place and that my levels were looking ok.
I found some handy tips in this article on the Bunnings website.
And another tip: The knee protectors are gold!
- Step 5:
After my bearers were fixed in place, I laid in all of my decking boards and used 4mm deck spacers to make sure they were all equally spaced.
- Step 6:
After getting the deck all screwed down, we enjoyed a coffee in the morning sun and started work on the step.
I'd chosen a corner step and am triggered by mitred corners that aren't level - it took lots of measuring to get everything in the right place. It's not 100% perfect, but close enough that I don't see the pieces out of line.
The forewoman checking level on my custom-length level!
Having the step deck boards line up with the picture-framed mitred corner was a challenge. YouTube and the Bunnings website were great resources.
- Step 7:
All done and with one coat of finish. It will take a couple of sands and coats before the new Pine starts to more closely match the older decking boards.
- Help and inspiration:
[article footer]
More inspiration for your deck build
Bunnings Workshop member danieltheman built a new deck for an outdoor entertaining area after fire destroyed his old patio.
Community member Tara86 built a huge D.I.Y. Merbau deck for outdoor entertaining with family and friends.
Get more inspiration from our Top 10 most popular deck projects.
[article footer]
