Hi Iwas wondering if i could get the measurement of the return panel frame of the
i need to replace my shower screen externally the shower is 870mm but i measure the actual return frame at 830mm
Hello @roblew
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the Mondella shower.
I'm sorry but Mondella does not sell their shower panels as a spare part. It can only be purchased as a complete shower set. The only panels that can be purchased independently are the Mondella frameless shower panels (see image below). These panels are standalone products and can't be integrated into an existing shower frame.
My best advice is to engage the services of a professional shower installer or an aluminium/glazier professional who can measure the exact glass panel that you need if you are intent on keeping the old shower frame. Otherwise, I suggest installing a new shower set and removing the old one that's currently there. It may be worth comparing the cost of a new shower set versus the cost of getting a custom safety glass panel cut, manufactured and installed.
Please note that working with glass is dangerous any accidental hit with a tool or when too much force is used can cause it to shatter. Please remember to wear personal protection such as appropriate clothing, closed toe shoes, gloves, goggles and a mask.
Hi Eric, i have every intention of replacing the entire shower, i just wanted to be sure this shower would fit my base
My apologies for the miscommunication. If you are looking at the Mondella https://www.bunnings.com.au/875-x-1830mm-chrome-semi-frameless-shower-screen_p0826221 . The exterior size of the shower is adjustable from 860mm to 875mm. It has been designed to sit inside the inner lip of the Mondella shower tray. I've placed an image of the specifications below.
Here is the link to the Mondella 875 x 1830mm Chrome Semi Frameless Shower Screen specifications and here is the link to the Mondella installation instructions.
However, if you are looking at the https://www.bunnings.com.au/estilo-900-x-1830mm-chrome-semi-frameless-shower-screen_p0012606 . The fixed side which is the return is 880mm but can be moved into the installation channel down to 855mm. The front side with the door is the adjustable section which can go from 830mm to 900mm. I've placed an image below of the installation manual which states the size of the shower frame.
For peace of mind, I recommend having the shower installed by an experienced professional. Correct installation is especially important to ensure the glass, frame, seals and fixings are secure and properly fitted, helping to keep the shower safe and watertight. Professional installation may also provide you with an installation warranty and appropriate documentation, which can be helpful if you ever need to make a warranty or insurance claim.
Estilo Shower
Mondella Shower
