Hello, I need help what I could do to seal the bottom of the shed walls? Dry leaves and mouse can enter. It is a metal shed with a concrete slab. Insulation on walls has been already done. I’ll attach pictures, I can also see light from the top of shed
Hi @217737,
Welcome to the Bunnings Workshop community. It is wonderful to have you with us.
For the bottom of the shed walls, it is generally best to create your seal from the outside wherever possible. This prevents water and debris from getting beneath the wall sheets in the first place, rather than trying to stop them once they're already underneath.
I'd suggest having a look at How to waterproof a shed floor. The method shown there uses an exterior seal around the base of the shed and, although the discussion is primarily about preventing water ingress, the same approach should also do a good job of preventing leaves and other debris from blowing underneath the walls. Depending on the size of the gaps, you could use a flexible exterior sealant such as Sikaflex 11FC Purform alongside some appropriately sized aluminium angles.
For the gaps created by the roofing profiles, you can use Suntuf Black Corrugated Foam Infills. These foam strips are shaped to follow the corrugations of the roofing and can be fitted into the gaps between the sheets and the shed structure. You will have to select an infill that matches the profile of your particular roofing, which we can certainly assist with if you can provide some images showing the profile.
If the foam infills press-fit firmly into place, you could simply leave them like that. If there are still small gaps or you want to secure them more permanently, you could apply some Sikaflex 11FC Purform around them to help hold them in place and seal the remaining gaps.
These two methods should seal things up nicely and prevent those annoying leaves from getting in.
Let me know if you have any questions.
