I’m trying to organise my shed which is open on one side and I’ll use it to stoke pool chemicals, garden tools etc. what shelves or storage units would be recommended for this space?
Hi @Amrit,
It looks like you've got a good amount of space to work with, so there are plenty of options for getting things organised.
Considering the shed is semi-open and there's the potential for moisture to get in, I'd lean towards storage that isn't going to be particularly affected by damp conditions. Something like the Pinnacle Heavy Duty Plastic Shelving Unit would be a good starting point. Being plastic, you don't have the same concerns about rust or timber-based shelves swelling if they get damp. You could then use plastic storage containers with lids for anything you want to give some additional protection from dust and moisture.
For the gardening tools, making use of the walls will save you quite a bit of floor space. The StorEase garage storage system has rails with a range of hooks and holders that can be configured to suit things like shovels, rakes, brooms and other long-handled tools. The Ryobi LINK storage system is another modular option worth having a look at.
Pegboard is another possibility if you'd like somewhere to organise smaller hand tools. @Prawns used Pinnacle metal pegboards in their garage, and there's a great range of hooks and holders that can be moved around as your storage requirements change.
I'd also recommend having a look at 10 ways to add garage storage and 10 ways to store tools. There are some fantastic examples from our members that should give you ideas for making use of both the floor and wall space.
Another project worth checking out is @lcooksey88's garage storage makeover, where they combined shelving, pegboards and overhead storage to make excellent use of the available space.
Also, allow me to tag @prettyliving, @Remarka6le and @Dave-1 to see if they have any suggestions for how they'd approach storage in a semi-open shed like yours.
Let me know what you think.
Good Evening @Amrit
I was thinking you might need a combination of shelving plus hooks due to the awning being open to the weather. The first hooks that @JacobZ has suggested would be good to use. You can create a home built timber version as well that will support multiple tools hanging from the wall.
Wall-mounted garden tool storage is what I was remembering :) It took a bit of searching to find it. So this plus the Pinnacle 2090 x 1820 x 540mm 4 Tier Black Shelving Unit (there are smaller versions) I would staff with the mesh shelves over the MDF due to the openes of your storage area.
To make your area easier to manage I would lift your existing pavers and relevel them. It may feel like a chunk of work but I have always foudn an easier place to access becomes much more useful.
